Pelican 1510 for HMC + HV30?
booggerg2
Is anyone using a Pelica 1510 to store the HMC? I need to carry a Canon HV30 with my HMC for airtravel. Will both fit in this case? I'm thinking I would prefer the padded divider set instead of the plucked foam set. One concern I have with the dividers is that it looks like it is broken down into two even width columns, so I'm not sure if the dividers will allow enough flexibility to fit both cams? THanks.
I have a 1550 and I use it for my Brevis and lenses. But I laid out my HMC 150 on it and for sure you could fit all your stuff,HMC and an HV 30. Oh yeh I took out the foam insert and out in the divider one I also have for it.
I think a 1510 might be tight for everything and the HV30.
It will be tight but should be able to make it work as long as you do not plan to carry a ton of acces in it also.
Pelican has a warehouse/distributor down the street from me and I looked at the 1510 (I brought the HMC and the HV30). As was mentioned, they will fit but not a whole lot else. It looks big on the outside but its pretty tight on the inside. If you want it for travel (and for the cameras only), its a good, solid, waterproof case. But for everyday use its too small IMO. I looked at the plucked foam one, I'm not sure if the padded divider one will work for you, as the HMC takes up nearly the whole inside of the case. I'd take both cameras to where they have one and try it.
