FS: Sony DSR-300, Glidecam, Tripod, plus MUCH MORE
fischtale
I have several miscellaneous production items for sale, along with a very complete Sony DSR-300 package with a lot of accessories. Items are available individually, but I will give a great discount for the whole camera package. Some items have slight cosmetic wear, but all items are in excellent working condition. To see photos of all the items, click here.
Misc. Items:
Bogen/Manfrotto Light Stand model #3078 - $40
It extends to a maximum height of 13' (4 m).
Aluminum Locking Collars: Made from pressure die cast aluminum.
Versatile Top Stud: This stand has a 5/8 inches top stud that has a 3/8 inches thread, and a removable 1/4 inches-20 thread.
Double Braced Leg Base: Provides extra stability giving the stand more strength
Bryco mini-DV tape racks (3 available) - $12 each
Model # MDV-50, Holds 50 tapes, heavy duty, wall mountable
Motorolla Headsets (un-opened) - $10 each
Model #53725, with swivel boom microphone, can be used hands free with VOX-capable Motorola two-way radio
Bogen/Manfrotto monopod model# 3245 - $60
The automatic, 3 section, monopod provides immediate single handed final height adjustment. Squeeze the trigger handle and the top section can be raised or lowered, release, and it locks in position. The lower two sections have a twist lock action for additional height adjustment. The top plate has a dual 1/4" - 3/8" camera fixing screw.
Max Height w/extended column: 65.4 inches
Closed Length: 26.8 inches
Leg Sections: 3
Max Load Capacity: 17.7 lbs
Weight: 1.1 lbs
Glidecam 4000 including arm brace - $350
The 4000 Pro is 18" tall and supports any camcorder weighing from 4-10 pounds.
Easy to set up and balance, they allow unrestricted booming and 360 degree panning.
Offset handle grip is attached to a free-floating precision Gimbal, allowing hand movement up and down and side to side, thereby isolating unwanted hand interference from the camera. The up and down movement alleviates the bouncing pogo-type action associated with other systems whose handles can't move up and down.
You can shoot upside-down, sideways, low near the ground, overhead and angled.
The system's free floating, precision gimbal includes integrally shielded bearings, two of which are housed in the unique Offset Handle grip. These precision bearings create the super-smooth and pivotable connection between your arm and the unit's Central Support Post.
Counterweights on the Base Platform can be quickly attached or adjusted while the system is resting in an upright position on its base.
Camera platform moves back and forth and side to side, allowing quick adjustment of your camera's horizontal balance. Camera's vertical balance is adjusted by varying the amount of counterweight disks on the base platform. When balanced properly the camera floats, ready for you to move into action.
For remote viewing, an optional LCD monitor can be attached to the mounting holes on the base platform.
Can also be used as a Monopod.
Camera Package: $3400
Sony DSR-300 with Canon YH18x6.7 Lens
Incorporating Sony's latest DSP (Digital Signal Processing) technology based on the TruEye
process, the DSR-300 realizes faithful color reproduction never experienced with conventional
analog and digital cameras. Drastic smear reduction and high sensitivity achieved by the newly
developed 1/2" Power HAD™ CCD provide more shooting opportunities, while maintaining high
picture quality.
DVCAM Recording Format w/ Dual Cassette
Total Level Control System
Edit Search
0.5 lux @ F1.4
800 TV lines Horizontal resolution
Canon YH18x6.7 Lens
Zoom Ratio: 18X
Range of Focal Length: 6.7-121mm
4:3 Aspect Ratio
Minimum Object Distance (M.O.D.): 0.9m
Macro Function
Size (W x H x L): 139.8 x 99.5 x 177.8mm
Weight (Approx.): 1.3kg (2.87lbp)
Bogen/Manfrotto tripod (510 head and 3141B legs)
The 510 Pro Video Head is designed for use with the new generation of CCD and smaller state-of-the-art ENG cameras. The 510 incorporates all the features required by Broadcasters, including an advanced three-step drag system which ensures smooth, repeatable pan and tilt control, plus smooth stop and starts. The variable balance adjustment with return to the center allows for fingertip control. Supplied with leveling bubble, quick-release plate, secondary safety lock and two telescopic pan handles. Max Supported Weight: 18.7 lbs
Lightweight high-tensile aluminium tripod uses high-strength plastic composite material to save up to 30% in weight saving without loss of rigidity or stability
Twin spiked feet are standard and a 3138 ground-level spreader is included
Designed for heads with a 100mm ball
Closed Length : 28 inches
Maximum Height : 61.5 inches
Maximum Load Capacity : 33.1 lbs
Minimum Height : 12.6 inches
Finish : Black anodized
Foot Type : Dual spiked
Head Bowl : 4 inches
Head Mount : 100mm bowl
Leg Diameter : 25, 16 tandem, 16 tandem (mm)
Leg Sections : 3
Material : Anodized aluminum
Series : 3141
Weight : 7.5 lbs
Anton Bauer Hytron 120 batteries (2)
Features RealTime display, which simultaneously indicates the remaining runtime and battery power on a built-in LCD. Runtime is automatically deducted in 15 minute increments, as calculated by the battery’s on-board computer which takes into account load, battery capacity and temperature. Weighs 5.5 lbs.
Portabrace camera bag
Heavy duty shoulder strap and comfortable leather hand grip.
Crush proof guard protects viewfinder. Secures in back seat of Vehicle, fastened securely with a seat belt.
Holds camera with on-board battery and most wireless configurations attached.
Dual purpose rear pouch expands the main compartment 3" or it can be an all-purpose pocket.
Special foam blocks hold camera in place and provide lens support.
Portabrace rain slicker model #STC-LSQ
3-ply Nylon, Fabuthane with soft tricot-backed protection
Ample vinyl viewing windows
Detachable front visor, triple zip bottom
Quick Change Battery Back
Rain-Fly for extra coverage
Anton Bauer AC adapter
JVC HZ-FM15 Focus Control
JVC HZ-ZS138U Zoom Control
NRG Ultralight on-camera light with spare bulbs (2)
NRG power adapter
Portabrace tripod bag
Sony V plates (2)
Bogen/Manfrotto tripod carry strap
