Is there a way to reduce or eliminate the noise?In general, Azden gear tends to be rather noisy.
Sorry I wasn't specific. It's for sure noticeably present on tape too.You said "noise when monitoring." Is the noise present on the tape or just in the headphones when monitoring?
Commerical noise-removal plugins (eg. DINR, Soundsoap) and EQ can help manage the noise on a recording, but they almost always do so at the expense of quality and transparency. Another strategy is to manually or automatically "gate" the signal, so that the overall level drops between lines of dialogue. The down side of gating is that the noise may become more apparent every time someone starts talking. It may take a combination of noise reduction, EQ and gating to bring about a subtle improvement in the track.Is there a way to reduce or eliminate the noise?
Rode NTG-2 -> (Forgot Cable Brand, for some reason) 15 Ft XLR Cable wrapped around pole -> Azden FMX-20 Mixer w/ Headphones -> (Forgot Brand Again) 6 ft XLR Cable -> DVX-100BCommerical noise-removal plugins (eg. DINR, Soundsoap) and EQ can help manage the noise on a recording, but they almost always do so at the expense of quality and transparency. Another strategy is to manually or automatically "gate" the signal, so that the overall level drops between lines of dialogue. The down side of gating is that the noise may become more apparent every time someone starts talking. It may take a combination of noise reduction, EQ and gating to bring about a subtle improvement in the track.
Frankly, the most effective way to reduce noise is not to record it in the first place. Mic self-noise is pretty much unnavoidable (quantum mechanics and whatnot), but an innexpensive mic will generally have a pretty high noise-floor. The same goes for other components in the signal chain; cables, preamps, mixers, effects units, and A-D converters (not to mention headphone amplifiers) can all add noise to the signal. The trick is to select high-quality gear and use it in such a way that the noise is kept to a minimum, preferably burried deep in the track.
JordanBlock is quite right about Azden gear, but the mixer may not be weak link in your signal path. It would help if you provide more information about your recording gear (mic, camera, etc.)
Note: The set up works fine if I go just Rode -> 15 ft Cable -> DVX-100B or Rode -> 6ft XLR Cable -> DVX-100B
I'm responding to you at 3 am on the East Coast, so I'mma try this when I get a chance during the day. Thanks for the info though!Are you using the same settings on the camcorder for both situations?
Going straight in with the Rode suggests that you're using the camcorder on the MIC setting.
Are you using the MIC setting while using the mixer?
You probably want to use the camcorder on the LINE setting when coming out of the Mixer. These types of mixers are designed to drive high output levels. So, the output stage amplifier has a corresponding noise level. If you turn down the master volume control to get the signal level so it works with the MIC input setting on the camcorder, then the signal is not high enough compared to the output stage noise. So, you get a poor signal-to-noise ratio. This would also be the case with the more expensive Sound Devices mixers.
There are mixers with output stages that are designed to interface with MIC level inputs on camcorders (primarily used with camcorders like the HV30, but can be used with camcorders like the DVX-100 to add additional XLR inputs):
http://www.juicedlink.com/index_files/CX_camcorder_XLR_microphone_adapter_audio_mixers.htm
Hope this helps you out ...
-R
-R
I've got a MixPre, and I know that I can't take the line level XLR outputs into a mic level receiver without TONS of hiss (for the reasons above).
If my only option is a mic level receiver, then I need to use at least 30dB of attenuation between the MixPre and the receiver, so I can gain up in the MixPre to get the signal above the noise level its the output drivers.
You're right. It's all proper gain staging. But that includes the various gain stages contained inside the mixer
1) MixPre into mic level input on camcorder -> tons of noise
