Happy Hopping
As far as I know the only camera that does well in AF in 24p mode is the Canon A1/G1 in their 24f mode. This is because the autofocus IR sensor is located on the side of the lens and is independent of the frame rate. Of course that also means you have to be careful about blocking the sensor if you are using a mattebox and want to use AF.
Set aside the $$$, is there any other brand name or model that is better? Because the A1/G1 is only 1440x1080, and it's tape, so I like chip and 19x12 much better.
Also, are you saying this is a design issue? that is, Canon can do something that Panasonic and Sony can't do?
