jujufactory
Carbonite Member
I've been looking at the Letus extreme and other 35mm adapters. These adapters are designed to be mounted on fixed lens cameras such as the EX1 or Z1. However they are relatively expensive. I'm wondering whether it isn't cheaper to just bypass the fixed les cameras and go with removable lens cameras (such as the Z7 or EX3) and use some sort of ring adapters to get the same job done. Are there ring adapters for the Z7 or EX3 which allow the same low depth of field end result as the Letus but without the awkward lens on lens compromise? Wont the ACM-17 get the job done?
