bronxjragon
mattsand i was hoping that you'd reply to my posting : ) only one who seems to know how to make a good d90 image
matt,
here's some stuff i shot today with color correction and using your d90 rescaler
http://www.vimeo.com/2347733
without buying neat video i wish i could scale up to 1080p because from teh first posting and images, it looks like it also cleans up the artifacts as well.
*p.s. don't bother full screening that video, artifacts galore
Maybe using an intermediate codec in a 2nd step?(...)
I have some doubts that this process will work so well with the 5D because of the H.264 block-oriented compression; the D90 is intraframe MJPEG, its artifacts create a pattern easily recognized in each static frame. The H.264 interframe artifacts doesnt create a pattern, it changes accordingly with the motion of image captured. Probably Neat Video will blur the 5D more than a reconstruction of the lost information. But Neat Video would work like it does with D90 with any other intraframe codec in the market, film included
i think you misunderstand the problem. it's not that the codec doesn't work with neat video, it's that neat video tries to recognize and learn the noise pattern of the image and with h.264 encoding it's not constant.Maybe using an intermediate codec in a 2nd step?
I've got it. I'm just wondering if the h.264 encoding is not the proper environment for Neat Video, why not using an intermediate codec at post-production which can be suitable for the task? I mean, for a similar result as it occurs with the D90's intraframe MJPEG.i think you misunderstand the problem. it's not that the codec doesn't work with neat video, it's that neat video tries to recognize and learn the noise pattern of the image and with h.264 encoding it's not constant.
/matt
how would an intermediate codec remove the blocks created by the origination codec? it might add some new that you could remove more easily, but that doesn't solve the original problem, does it?why not using an intermediate codec at post-production which can be suitable for the task?
#1 The Nikon guys are ***holes for taking this idea so close and yet so far. CREATE a freaking firmware to fix this already!!!
#2 I refuse to believe there isn't tech head around here capable of creating an AF script for this. DO IT and then sell it to Nikon or AF...or both (but use us as guinea pigs for free before)
#3 In the meanwhile could someone write a "D90 Stair-Stepping Removal for Dummies" type of tutorial? I mean a VERY BASIC in your face step by step tutorial for (technically speaking) mentally delayed individuals such as my self. Or maybe do like one of those Creative Cow tutorials where they film the computer screen while narrating what they're doing (and then post it on vimeo).
It's not a bug, they did it on purpose to save clock cycles and memory, thus they can't fix it either. Just deal with it in post. no i won't tell you how, it's all out there.
At times, a removal does seem obvious, sometimes does not. The hassle is there, just not so noticeable or noticeable at all. There's a margin where the flaw can be accepted for the job or not (with the due respect -- like a woman :laughWhich task? The point is to remove the dct noise and recompressing can't possibly help no matter how you turn it. The better the intermediate codec the more of the original structure it preserves.
(...) Probably Neat Video will blur the 5D more than a reconstruction of the lost information. But Neat Video would work like it does with D90 with any other intraframe codec in the market, film included
yes, i see what you're saying but it's impossible. it's just basic signal theory. even if you succeed in removing it you will have removed information too unless you've figured out a way to differentiate between signal and noise, which brings us right back to the original problem. you don't even need to assign any properties to the "intermediate codec" for this logic to hold. i'm not explicitly stating that neat video can't remove h.264 artifacts, merely extrapolating the consequences based on that assumption.Or then, getting a somehow method in order to create such pattern which could be more effective and take away the non-pattern blocks too
that must be why i developed a plugin that takes about 5 seconds to download, 2 more to apply, and doesn't even have any setting. did i mention that i'm giving it away for free? did i also mention that i've posted around half the posts in the stairstepping thread. i'm one of the fcking founding father for crying out loud. without me you wouldn't even know what stairstepping was.You're a mean bad man
Ok, Mattias. And about the 1st one?yes, i see what you're saying but it's impossible. it's just basic signal theory. even if you succeed in removing it you will have removed information too unless you've figured out a way to differentiate between signal and noise, which brings us right back to the original problem. you don't even need to assign any properties to the "intermediate codec" for this logic to hold. i'm not explicitly stating that neat video can't remove h.264 artifacts, merely extrapolating the consequences based on that assumption.
/matt
