Will Clegg
From Macworld.com...
Also, the battery will not be removable anymore.Ports: FireWire 800. 3 USB ports, ExpressCard 34 slot. Battery life indicator, Ethernet, mini DisplayPort. About what you'd expect. New glass trackpad as on the previous unibody MacBooks. 2.93 GHz, up to 8GB of memory at 1066 MHz DDR3 ram. Built-in both the GeForce 9400M and the GeForce 9600MT. 320GB hard drive standard. Up to 256GB SSD drive option. Plus the usual backlit keyboard, iSight, magnetic latch, etc. Works with the new DisplayPort Cinema Display.
For the last 8 months running, if you look at the list of laptops sold in US, MacBook has been #1 on the list. So here's the 17": 0.98 inches thin. World's thinnest 17-inch notebook. It's 6.6 pounds, which also makes it the lightest 17-inch notebook. 1920x1200 LED backlit. 140-degree height/120-degree width viewing angle. 700:1 contrast ratio; 60% greater color gamut than previous notebook display. It's got a glossy display, so they've also got a $50 anti-glare option. Same display properties as last 17".
