Best Tape Stock for DVX-100B
film615
I just purchased a DVX-100B from Ebay. What is the best videotape to use with this camera?
Thanks.
film615
I it a new camera? If yes then use Panasonic AY-DVM63AMQ. IF not find out what was used in it before you bought it. Mixing wet and dry lube tape is not a good thing for the camera.THe Panasonic above is a great tape, always used it in mine and never had a problem.ALso do a search here and you will find countless posts on this subject.
u can also try panasonics PQ's. however based on the reading i have done here it most tapes will do...just don't change brand's or change from wet to dry lube(or vise versa) .If u do either then use a tape cleaner b4 using the other brand.
Yes jambredz is correct in never mixing Panny tapestock with any other but I have always used Sony HDM-63VG with great results since most of my clients provide the stock. Good luck.
Yes, Panasonic AY-DVM63AMQ are the bests.
I don't think that they are discontinued because they are the most recent ones. The AY-DVM63MQ (Master quality instead of Advanced Master Quality) are discontinued.
Me, I get them for about $6 Canadians.
Where? i'd love to get em for that price. i'm in mississauga
When the MQs were discontinued, I switched to the PQs. They're great. I've had zero problems.
Stick to the 63 minute tapes, though. The 83 minute tapes have thinner tape that can jam easier.
Panasonic AY-DVM63PQ
I've been using Panny AY-DVM63PQ...never had a problem...very nice.
