Thomas Lew
I had a peculiar hunch a few hours ago. AIC and ProRes files are known to be large, and I found myself wondering if their file sizes once rendered into a .mov will be likewise in comparison to each other in terms of file size. Pretty much, will ProRes footage which is larger than AIC footage stay proportionally larger once they are both rendered into a video under the same settings? Did I mention I am a scientist as well as a detective?
Hypothesis:
AIC footage (smaller than the other) -> render to .mov = Smaller file than the other
ProRes footage (bigger than the other) -> render to .mov = Bigger file than the other
The experiment:
Using the same 5 second avchd clip, I transcoded it into both AIC and ProRes formats. Then in final cut, I rendered each as a .mov with the SAME settings. My findings baffled and bewildered me.
The result:
AIC footage (124.6mb) SMALLER -> render as .mov = 6.2 LARGER
ProRes footage (165.mb) LARGER -> render as .mov = 5.8mb SMALLER
Conclusion:
Ask dvxuser members for help!
Hypothesis:
The experiment:
The result:
Conclusion:
