Does anybody know how wide of a lens you can get without getting any vignetting while using the Letus Extreme on the HVX? I've been using a 24mm and I'm no where close and I would like to go wider.
I think he means "stock" as in without any adapters. Wide angle lens wont have a shallow depth of field anyway. This defeats the purpose of using 35mm adapter.
-Max
When I said stock I meant using just the lens on the camera. No point in buying any lenses for the letus because you cant go under 19mm and the HVX is about the same as that. If you need something really wide you will have to buy a lens for the HVX itself.
