Well, there are a few ways to go, and they all depend on budget.
First, one mic can do the job if the blocking and dialog are well rehearsed and consistent from take to take. But it also depends on how far apart the actors are and how far the mic has to move to get from one person to the other. So for that size of group, not as practical.
Another option is to get a second Octava with fishpole and mount. This also requires a second operator, but two mics can share the duties and get much better coverage. Again, rehearsed and consistent blocking and dialog are important.
Lastly, and this takes a much larger budget, would be five lavs. This also requires a larger mixer, and ideally a way to run iso record channels on all mics.
It's not uncommon to have two mics/poles running on a room with a small group. So unless you have the budget to outfit with lots of wireless and a multi-track recording setup, you might want to look into the second Oktava rig. You might also want to get a couple of Sound Devices pre-amps, which allow the operators to have headphone monitoring of their own mics as well as a return feed from the mixer.
i like the idea of having lavs and a boom mic possibly would that work? maybe two actors lav'd up and the boom covering the other three actors would that work?
3 actors are sitting on a couch and two are in chairs close to the couch so not too far apart from each other.
what are a good set of lavs to go with in a situation like this?
and phasing..
To the original poster, are you doing this all on one master wide shot? Is this scripted
dialog or conversation?
If its scripted dialog and you're getting different framings (IE:singles,..)
you do realize you only need to cover the people who are on screen at a given moment
with the mic. Just dont have overlaps and you're golden.
If this is a "non" scripted video, cover it with 1 mic if possible, if thats not..
then 2 booms OR 5 wires...
Unless there is a "host" style person who is going to do the majority of the dialog..
then personally I would wire him, cover the rest with the boom. Split track of course.
As you can see, audio is an ever changing thing depending on the situation...
and no "one" answer will work in every case.
yea this is a scripted scene so i guess the best option is to do like you said and just block the scene so only the person/people that are talking are on camera and there's no overlap.
just out of curiosity can i get a good lav setup with about $500? my next project i'll be needing them for some wide angle scenes (2 actors in dialogue) where the actors are having a conversation.
