FS: Bogen / Manfrotto Pro 3182 Tripod System
jqwest
This Professional Tripod System consists of the 3182 video tripod, the 503 pro-video fluid head, and padded case. With a 17.6 lbs load capacity, it is perfectly suited to support high end DV equipment, such as the DVX100 w/35mm adapter mount. Tripod has been opened from original shipping package but has never been used and is in MINT condition.
Selling for $625 with FREE Shipping.
Specifications:
351MVB Lightweight Professional Tripod Legs:
Material: Aluminum
Load Capacity: 44.1 lbs
Bowl Diameter/Thread 75mm 3" Half Bowl
Minimum Height 33.1"
Maximum Height 61.1"
Leg Stages/Sections 1/2
Leg Lock Type Flip Levers
Center Brace/Mid-Level Spreader No
Spiked/Retractable Feet Spiked
Folded/Transport Length 37.5"
Weight 8.0 lbs
503 Fluid Video Head:
Load Capacity 17.6 lbs
Diameter/Thread 3/8-16
Counter Balance System 3-step
Counter Balance Range 0 - 8.8 lbs
Quick Release/Wedge Plate Yes, with 1/4-20 and 3/8-16 mounting screws
Balance Plate Yes, with 58mm of travel
Tilt Drag Continuously variable
Tilt Range -60° to +90°
Tilt Lock Independent
Pan Drag Continuously variable
Pan Range 360°
Pan Lock Independent
Leveling Bubble/Illuminated Yes/Yes
Height 4.5"
Weight 4.4 lbs
Payments accepted via PayPal only. Will only ship within continental U.S.
