Compressor is there...but it's not
Jim Brennan
VHS Member Old Skool
I had to reinstall my FCP suite (FCS2). Now when I try to export something (or open something) in Compressor, it opens (It says compressor in the corner) But nothing is there. Just the name of the program. I tried opening all the windows manually, but that's not fixing it.
Any thoughts?
Would it be possible to detail what you did with what?
For example, what OS did you commence with, and why did you reinstall FCS2?
What OS and FCS2 updates have you run?
Sorry,
I'm running Leopard on an 8-Core MacPro with 8 gigs of RAM. I haven't done any updates since I re-installed today (trying to meet a pre-holiday deadline). I re-installed the Suite (no content, just the apps) because FCP kept freezing up.
I was in a sequence I had previously exported through Compressor, but made a minor change in. I went ahead and output a QT file to throw on a DVD for the client. But whether I try to open that QT file with Compressor, or export the sequence through it, I get the same result.
