Hey Everyone,
I'm premiering my featurette next Saturday at an indie theatre, and I'm feeling a little panicky about my preparations and set-up for the screening. The theatre owner is very nice but doesn't know a whole lot about the technical side of his set-up (I'm not sure I know much more) and I went in today for a test and it didn't go so well. He's running an Optima DLP projector hooked up to a Sony DVD player (more specs below).
I think I have a few ideas as to why my footage didn't look right and plan to spend the next few days researching and experimenting before I go back for another test of Friday, but I thought it might be smart to drop a note to see if anyone had any ideas on what I'm doing wrong or should do differently.
Project is shot in 720p/24p and has played very much to my satifaction on an SD-DVD created by exporting with the DVD Best 90 min 16:9 setting in Compressor.
Here's the set-up at the theatre:
Here are the issues that I noticed after beginning playback (my menu looked pretty much the way it was supposed to):
The first thing I am wondering is if I need to create a new DVD with better, more specific settings. My project is a 45 min featurette.
Other questions:
Many thanks to anyone who has even read this far. If it helps, you can view a sample of how things are supposed to look by watching the teaser trailer on our web site: http://www.sexandjustice.com.
I'd be very grateful for any advice. My first step after posting this is going to be to crack open the manuals for the projector and DVD player and start taking notes.
And I'm really wondering if that Quicktime file on the Macbook Pro is the way to go. We're anticipating a decent crowd and we're marketing like crazy and while I'm excited I really want to be sure that people are going to be able to view our little indie feauturette at the highest quality.
- Projector: Optima DLP EP 739. Here are the specs that I'm going to go read up on after writing this post: http://www.optomausa.com/Product_detail.asp?product_id=5)
- DVD player: Sony DVP-NS715P. Specs here: http://reviews.cnet.com/video-players-and-recorders/sony-dvp-ns715p-dvd/4507-6463_7-20216810.html?tag=mncol;rnav
- The projector is 45 ft away from the screen
- The screen is 18 ft by 12 ft
- The devices are hooked up via an S-Video cable
- An overall fuzziness to the picture that seemed separate from the focus settings on the projector (menu showed in good focus, and I wasn't able to correct focus by adjusting anything).
- Everything originally played very dark, which we were able to correct mostly by increasing the brightness, and very red, which we similarly addressed by bringing the reds down in the color settings for the projector (although the reds on my menu seemed mostly okay)
Other questions:
- I color corrected within FCP using my Cinema Display as a reference monitor (no other choice, out of budget and time and I am personally, literally poor). If my color decisions (and I monitored everything that I did on my scopes) look safe on that display and on my test DVD played on several different setups...can I assume that they aren't the reason why my footage looks dark and red on the projector? Or should I be making smaller, less-pronounced adjustments because of the sensivitiy of the projector? I did bring my whites slightly towards red and yellow on many sequences...but I didn't go crazy with them. Also darkened some shots (or left some shots dark in spots if they were meant to be that way) but I didn't crush any blacks and watched my waveform monitor.
- Will much of this be solved with a higher quality DVD encode? Maybe using the settings suggested here by Will Clegg (which I will try...as soon as I can afford to let my computer run for a day during compression)?
- Or should I be thinking about exporting a Quicktime Movie at a very high quality (settings suggestions welcome) for running through my MacBook Pro into the DVI input on the projector?
