THIS ITEM WAS SOLD!!!
For sale is a Cavision two-stage matte box system including the following:
MB4169H-2M two-stage matte box
Asking price is $500 for the whole matte box system. Cash or PayPal if you're located in the New York City area, otherwise PayPal only. Packing and shipping is extra and will be calculated at time of sale. Send me your zip code and I will give you an estimated shipping cost.
Email or PM me with any questions or if you need additional photos.
- Two filter stages: one with 360 degree rotation (270 for FX1/Z1 cameras) and one with horizontal insertion
- Two 4x4" and one 4x5.65" metal filter trays
- Filter size: 4x4" fit in all stages, 4x5.65" in stationary stage; up to 4mm thickness
- Filter tray security lock: yes
- Fit Lens Outside Diameter: 120mm and under (with appropriate adapter rings which are included)
- Construction: Aluminum and ABS
- Extra wide hard shade specifically designed for HD 16:9 format
- Rotating filter stage for use with polarizing and graduated filters
- Two carbon fiber rods
- Height adjustable front bracket for connecting a matte box
- Balance bracket with tripod connection thread
- Mini-DV plate with vertical and horizontal adjustment, featuring uniquely designed locating pin for enhanced stability
- Rail Diameter: 15mm
- Rail Length: 250mm(10")
- Rail Spacing: 60mm (r.c. to r.c.)
- Rail Wall Thickness: 1.8mm
- Rail Material: Carbon fiber
- Front Bracket Height Adjustment: 25mm
- Back & Forwards Adjustable Length: 200mm
- Fits Cameras: Canon XLH1 & XL1/2 & GL, Sony VX-1000/2000 & FX1/Z1 & PD150/170, Panasonic HVX200 & DVX-100 and more
- Plate Horizontal Adjustment: 60mm
- Mounting Hole: 1/4" & 3/8"
- Fits On: Consumer, Miller, Cartoni, Vinten and Sachtler ENG tripod heads
- Plate material: aluminum
- Includes R156025 bracket for15mm diameter rods with 60mm spacing; 25mm t-part slot
- Both handgrips offer swivel adjustment
- Compatible with 15mm diameter rods (60mm r.c. to r.c. spacing)
- Ideal for use in conjunction with a shoulder pad system
- Excellent for use with hand held shots as camera stability and smooth movement is enhanced
- Redrock Micro stainless steel machined
- Rail Length: 457mm(18")
- Cavision MBF-5P French flag
- Two Kish Optics lens donuts to prevent any stray light from entering the matte box and causing lens flares
- Porta Brace FC-1 filter case. The filter case holds 4"x4" and 4-1/2” diameter filters (and P2 cards) in an "accordion" case that has five padded sections. The handy pocket across the front has room for filter tissues and a small bottle of cleaner. A see-through window on top helps you organize and label the contents. A large belt loop is sewn on for waist carrying.
