Tim Naylor
Got the V2 Rods/Baseplate about a month or so ago. Only used with the HVX on its own - no adaptor. Loved the build and the adjustability of it. Finally set it up with an adaptor (Ultimate). I plan to take it to New Orleans for a week long job down there and I figured I'd build it up and get everything tweaked out. Up to this point, I've only used the Ultimate with my Zacuto / Z Riser setup.
So here's the review:
Build:
Very Good. Next to no twist or flex. Well machined. Knobs could be a bit bigger but not a deal buster. All threading works well. Very close to Zacuto quality.
Design:
Excellent. I love the fact that the block that attached to the tripod is separate from the sliding baseplate system that attaches to the camera. This allows considerable for and aft adjustment to get perfect balance. This is critical as different lens swaps often require rebalancing. Between the tripod block and the sliding quick release baseplate, you've got perhaps five inches of travel. Real nice.
The Riser (or Step Down depending whether you go snorkel up or down) is very simple in design and has no flex. It comes with an extender bracket if you need more travel (I didn't). No play whatsoever. One end clamps the rods while the other end, threaded rods screw in. It's compatible with Zacuto threaded rods.
Another nice touch is the raised camera platform is enough to keep my monitor bracket from bumping into the HVX battery.
Adjustability:
Excellent. Adjusting X or Y was as simple as loosening two allen bolts for side to side and two more for up/down. There are additional holes tapped in the block that will allow you to accommodate just about any camera's layout.
Price:
At 700 for Rods, baseplate, and riser it's a good deal. I would recommend additional rod lengths to accomodate long lenses.
Summary: everything about this set up is really well conceived for 35 adaptor set ups but it also works extremely well for just a naked camera. The best feature without a doubt is the separate tripod block from a sliding quick release plate for camera.
Strong recommend.
Tim Naylor - DP
www.timnaylor.com
Build:
Design:
Adjustability:
Price:
Strong recommend.
Tim Naylor - DP
www.timnaylor.com
