Fs: Nebtek neb70hd 7" lcd in the uk
Paul Llewellyn
AS NEW, ITS ONLY BEEN USED FOR A COUPLE OF HOURS TESTING. Never been used on location.
IT HAS THE LI-PANASONIC BATTERY UPGRADE.
I'm looking for £850 + postage.
"Designed by the Film & Video Professionals at NEBTEK with the needs of the industry in mind... Professional Composite, S-video and Component Connections, 5 Display Modes, Underscan, Bluescreen, and Video Peaking (which allows for those critical focus situations). All of our standard features are present as well... Excellent Picture Quality, Wide Viewing Angles, High Brightness, Daylight Coating for outdoor visibility, and 10V to 30V power compatability. The Top, Bottom & Side mounts allow for a wider range of mounting options. Two different Input/Output box configurations allow cables to come straight off the back (for Steadicam use), or to be hidden behind the monitor (for Film Camera Use). It also offers a Vertical & Horizontal Image flip function, making it an excellent choice for use with a 35mm Lens Adapter that inverts the image.
4:3, 16:9, 16:9 w/ 4:3 Matte and Anamorphic Display Modes.
Focus Detail, Blue Screen and Underscan Functions.
Horizontal & Vertical Image Flip.
Brightness, Color, Contrast & Tint.
Resolution: 800H � 480V (RGB)
Contrast Ratio: 400 to 1.
Brightness: 600 NIT/Candelas
Input Signal: NTSC/PAL auto recognition
Video Input Connection: Composite BNC, Component BNC & S-Video Inputs.
Power Supply: 12V~30V DC regulated.
Power Connection: 4-Pin XLR (Power-regulated), 2.1mm DC (Power-12V only), 6-Pin Hirose (Power-regulated, Audio & Video)
Current Consumption: 700mA
Dimensions: 7.5"W � 5"H � 3"D
Weight: 2.5 lbs"
