you havn't got the write protect tab of the SD cards in the wrong position do you?
No, the write protect is unlocked
I've checked all the user errors I can I think
I'm trying to use the Extreme III 30MB/s card
I'm trying to install the firmware and need some more help. After installing the usb driver I double click on the binarypackageloader.exe and it gives me an error. Says "The application failed to initialize proper (0xc00013..) Click on ok to terminate the application."
Any thoughts?
Thanks so much
yes, used that port. Installed the drivers. I tried on my vista computer after and it opened the binary loader exe but the click to install button is greyed out due to this error.
Login Mode Error90005)
<<Check the Target!!>>
Turned off and turned back on tried again and the same error. I am in camera mode and everything appears to be connected properly.
The drivers were connected fine.
I believe so, for vista. on xp wouldnt load, so left wondering.
