FS: Varizoom DV Traveler Camera Support System VZDVTRAVELER
sick boy
SOLD
Hello,
Up for grabs is a Varizoom DV Traveler Camera Support System with case. This is one of the most confortable systems I have used. I have found the stability to awesome with smoot shots, little to no jittering and extremely easy and quick to assemble. I am also including a very large case for transporing and storage. The case is from power tool cases that fit everything perfect, plus some. Also I am including is some fittings that replace the spring at the stableizer bar. I noticed when i first got the system the spring they provide is not that stable and the camera seems to wobble left and right. With my handmade connectors, I have been able to achieve great shots, and all though not receommened, I found I can go handless for a brief amount of time using my connectors. I have included extras incase you lose one. The system is in great condition, showing little signs of wear. There is a few slight chew marks from from being knocked around in transportation, but besides that, cosmetically great looking. Everything ships out usually same or next day.
Info from Varizoom:
Description
Combining the best in versatility, comfort and compact design the DV Traveler goes anywhere you do.
VariZoom's all new DV Traveler compact, shock absorbing support is the solution for lightweight yet extremely solid camera support. The telescoping shoulder arch can extend, retract, and rotate to the videographers perfect position. This unit can also fold flat or completely remove the shoulder arch with no tools for storage or travel. Also included is our rotating accessory mount and non-slip shoulder cushion.
The unit is made with precision and machined to the highest standards, made from soid materials to make support rock solid without any flexing. Long handgrip arms provide plenty of room for mounting a lens control.
The abdominal support is a spring-loaded suspension pod that distributes the camera weight while providing shock absorption. The support is constructed from 2 adjustable spring loaded telescopic sections designed to negate camera shakes and bounces. Adjust the horizontal position of your camera to comfortably view the LCD screen.
The suspension pod also allows smooth control over the height of your shot. Easily shoot at the eye level of your subject without uncomfortable bending at the waist. Even shoot over a crowd of people by simply raising your camera. No matter your height you will always get the right level shot.
* Telescoping horizontal bar allowing for perfect adjustment for eyepiece and or flip out monitor
* Bendable? Formable? arch adjustment
* Quick release camera mount
* Rotating accessory mount for lights, monitors, microphones and more
* Super plush cushion shoulder pad
Specifications
Weight 4.5 lbs
Full Width 9"
Full Length 21"
Folded dimensions 23" X 10" x 3.5"
Pod Min. Length 18"
Pod Max. Length 32"
Compatibility Camcorders up to 7 lbs.
Includes Suspension pod, padded shoulder support rig w/ quick release assembly, adjustable belt w/ holster
This system goes for $449 plus shipping. This is your chance to save over $130!
$320 for everything, shipped
includes ups ground shipping. (ships in original box I received it from Kessler) Payment through payment, please make sure your address is confirmed. Typically ships same day by 4pm eastern.
PM if interested.
Thank you,
Tim
Yes, it is aluminum so it is pretty malleable to shape. Obviously you don't need to bend it a lot to get it where your comfortable with, so it is pretty easy. This system is the best when it comes to conforming to your needs and body, I highly recommend it, it is just not as popular as other models out there so it has taken time to gain interest.
Thanks!
Received item in two days. Sick Boy is a great seller, everything was in immaculate condition, great deal. Highly recommended
