FS: Kessler Crane 5.5Ft KC-5.5 Ultra
sick boy
Sold
Hello,
For sale is a Kessler Crane KC-5.5 Ultra kit. The kit includes the 5.5ft crane (KC5.5), the vertical brake and the tool-less package. The vertical brake allows you to lock in place the position of the vertical plane of the crane. The tool-less package is a kit that includes the hardware for quick and easy assembly of the crane. The tool-less package comes with everything shown in the picture.
Info from Kessler Crane:
Specifications
Camera capacity: Up to 50lbs. in under slung position
Unit weight: 15 lbs.
Folded length: 48 inches.
Extended length: 5.5 ft.
Distance from tripod to camera: 3ft
Total vertical movement: 6 ft.
Features
360 rotation..
Invertible camera platform for Under Slung or Over Slung Positions.
2 arm design for maximum stability and minimum wobble.
Internal sleeve bearings insure incredible smoothness.
Constructed of high grade 6061-T6 aluminum.
Coated with a flat black non-reflective finish.
Right and left hand set up option.
Has rear control handle included.
Manual and automatic camera tilt control.
Sliding weight bar to easily achieve perfect balance
Uses standard household style exercise weights. (1 inch hole).
Breaks down into two easily transported sections
All parts are precision made and held to +/- .005” tolerances.
Condition:
I have used the crane twice for some commercials. There is little to no wear and I would considered everything to be almost as good as new. The only real obvious sign of wear is the foam pad on the camera mounting bracket show in the picture below. Besides that, everything is in great condition.
This kit sells for over $540 plus shipping. This is your chance to save tons on a an awesome rig.
$430 or OBO for everything, shipped
includes ups ground shipping. (ships in original box I received it from Kessler) Payment through payment, please make sure your address is confirmed. Typically ships same day by 4pm eastern.
PM if interested.
Thank you,
Tim
