Gyro Stabalizers - The "NEW" 35mm Adapter
Why does that site (the first one) look like it was built in the fifties!? A website update could do them some good, but I'd still like to see these in action:thumbsup:
i have the ks-8 and i love it . will even work better with my new lighter hpx170. i shoot with 5d as well but never needed to mount on my 5d will try it monday . up in the heli to shoot some seaplane footage. will try with a 300 2.8 is. lens. i don,t know what the res on the old 5d video is but will find out. crap compared to the new 5d mark2.
Be sure to post some sample here! :beer:
Jetaddiction,
We are now all waiting with baited breath! The first canon non-professional footage has surface today, and it is full of jellovision like the d90. See the 2nd video here -
http://www.dvxuser.com/V6/showthread.php?t=148196
There is talk about what the pro's have done to hide it in the example marketing footage. Did they just not pan, or was it the use of gyros?!
So if you could please please if you can try and get a fast pan past a vertical line with the gyros on, it might put it to bed! :)
cheers
PRICE LIST REVISED March 20th, 2008
Click on the blue part # to access our new E-commerce Store
GYRO KITS (click on item # to see pictures)
KS-12
GYRO with Inverter
$10,000
KS-8
GYRO KIT
$4,000
KS-6
GYRO KIT
$2,800
KS-4
GYRO KIT
$2,000
KS-2
GYRO KIT
$1,600
All kits are complete with KBC 115V Charger,
Inverter, Battery pack, CIG Adapter Cord in a iM2200 Storm Case.
MODEL
GYROS LISTED SEPARATELY
LIST PRICE
KS-12A
THE CHIEF
$8,800
KS-8
ADMIRAL GYRO
$3,500
KS-6
COMMANDER GYRO
$2,200
KS-4
UNIVERSAL GYRO
$1,600
KS-4A
UNIVERSAL GYRO with attached inverter
$1,800
KS-2
EXPLORER GYRO
$1,300
KS-2A
EXPLORER GYRO with attached inverter
$1,500
SINGLE OUTPUT INVERTERS
SSV153-24
KS-12 INVERTER 24-32VDC
$1,200
KI-28-6
KS-6/8 INVERTER 28VDC
$350
KI-12-6
KS-6/8 INVERTER 12VDC
$350
KI-28-4
KS-4/2 INVERTER 28VDC
$325
KI-12-4
KS-4/2 INVERTER 12VDC
$325
KATT
12 Volt Attached Inverter for KS-2 or KS-4
$200
DUAL OUTPUT INVERTERS
KI-28-D
KS-2/8 INVERTER 28VDC
$400
KI-12-D
KS-2/8 INVERTER 12VDC
$400
4 OUTPUT INVERTERS
KI-28-Q
$600
KI-12-Q
$600
BATTERY PACKS AND BATTERIES
KPB
BATTERY PACK (BELT)
$ 125
KPB0
BATTERY ONLY
$ 60
CHARGERS
KBC
6 HOUR 115V/230V auto sensing charger
$ 130
KQC
3 HOUR 115V/230V
$175
EXTRA EQUIPMENT
KGC
GYRO CORD 2' COIL
$ 75
KGC-12
GYRO CORD 12' CABLE
$ 110
KCA
CIG ADAPTER CORD COIL
$ 75
KBA
BINOCULAR ADAPTER
$ 75
KSC
STANDARD CARRYING CASE
$160
KLC
LARGE CARRYING CASE
$180
Heh. There is always shooting wider and using "Smoothcam" in FCP. I've used it occasionally to good result...
Those gyros aren't too pricey compared to some, and if the ks4/6 kit $2k-$2k8 will work on every camera I've got, and every still camera, and steadicam, and d90? Hmmm... might be worthwhile... Especially if you can take a cheap steadicam like a merlin or something, whack this on it and save yourself $7k on a flyer or above... :) I mean the steadicams are rated by weight, but i find the smaller ones just too flighty, but gyro might make the difference. Wild if it turns a featherlight dslr into something that improves "handheld" style footage into something usable. Imagine shooting a club scene in low light handheld, with just the d90 and a little gyro underneath it!? You wouldn't see some of the gait type issues anyway with the rest of the movement in the shot...
Reading about it I've found out that
1) they are noisy (how much? anyone knows?)
2) takes two, at right angles, for full stabilization
3) you cannot pan or tilt the camera rapidly
4) they take about 5 to 10 minutes to harm up (to come up to full speed)
but
5) they work
anyone here had any experience to shoot video (with sound) with those?
but
5) they work
Yes.
Best way is for you to go to your local rental house and check some out.
Yes.
That would be the way if I lived in US, in Brazil is kind of difficult
portable gyros are more of a photographic gear for aerial shots, too specialized to rent over here
I also read that after the gyro got to full speed of 20000 RPM (!!) you can detach the power cord for a silent operation of some minutes, is that true?
Depends on the ball bearings used, the construction of gyro, etc...
Perhaps some can post some videos here.
I think they also take ~20 minutes to "cool down" / stop running.
Even with two of the cheap gyros you would be at the price level of an EX1 with Letus Ultimate with lens included and you could save few thousands by not bringing a lightning kit ;)...
