timmytimetravel
Here it is.
More later when the stores open and I can get a longer hdmi cable. So judge not by the grain
The movie is encoded in h264 to get it small enough up onto dvx. Full uncompressed one can be found at link below for testing.
You can note that the only way to get rid of the focus frame in the middle is to switch it to Portrait or portait nightscene mode. This then limits automatic functions but doesn't limit locking them in before going into LV mode using AE-L and then using manual aperture on the lens. If you hit record on the unit at the same time (which it lets you do), you can then get rid of the square in other modes, but you gain a flashing "Rec" and counter in the top right of the frame... Trade offs but some flexibility depending if you are an auto or manual type bod.
Note also blackmagic hdmi intensity pro will not sync with this in 1080i mode. It will however sync when pushing the menu button as shown by the capture sizes below. That may suggest that it can put out 1080 in that part of the internals, but somewhere else inside it is upscaled, or simply just doesn't let you output 1080 from liveview. Firmwareable? maybe... If anyone has any other tricks you want me to try to try trick it, go ahead and suggest
It doesn't look like the aliasing on horizontal/diagonal lines is due to compression as you can see by the tub pic.
It also doesnt look like it outputs audio over HDMI! I tested with another cam that does, and it works fine.
Aside from getting clearer shots in better light open to suggestions for any more testing.
Cheers
H.264 compressed
http://www.dvxuser6.com/uploaded/40285/1222281616.mov
Uncompressed.
http://rapidshare.com/files/148077641/femsapien_d90_8bit_short.mov.html
http://rapidshare.com/files/148080750/85mmf1.4.pct.html
http://rapidshare.com/files/148080751/85mmf1.4_pic2.pct.html
http://rapidshare.com/files/148080753/menu720.pct.html
http://rapidshare.com/files/148080754/menu1080.pct.html
Cheers
H.264 compressed
Uncompressed.
