edthomas75
I have two products for sale - which I'll sell separately, or together as a package:
(A) MARSHALL V-R70DP 7 inch Monitor
This product retails new at £722.62 from
http://www.dsvideo.tv/marshall_1628.php
Full spec below.
This is the monitor itself, plus BNC cable.
I'm also selling:
(B) MARSHALL V-DV-PWR1, 12 VDC V-Mount Power Adapter for NP-Fxx
Powers the V-mount monitor using two standard Sony camcorder batteries.
This product is hard to find in the UK. It retails new at $243.90 from:
http://www.plasma.com/marshall/lcdAccessories/vdvpwr1.htm
This is the power adapter, plus two Sony batteries and a charger.
These items are in Somerset, UK. I can package up and send by your chosen courier.
Thanks,
Ed
More details:
V-R70DP
Manufacturer details:
"The Marshall V-R70DP is the successor to the V-R70P. Significant improvements over the previous model include our Completely Digital TFT-Megapixel high resolution LCD screen with 1.2 million pixels, V-Mount battery adapter, 4 pin XLR power jack, and optical grade polycarbonate screen protection. Analog signals are digitized using an advanced 10 bit process with 4x over sampling and adaptive 5 line comb filter plus exacting color space conversion. Video is scaled to fit on screen in the highest resolution using a state of the art LSI that incorporates 4 x 4 pixel interpolation with precision Gamma correction to product the best images available."
FEATURES - Marshall VR70DP 7 inch Wide Screen LCD Monitor:
Durable metal enclosure
"V" Mount battery adapter included
Runs 4 to 6 hours on optional 50WH battery
High Resolution 7-inch wide screen 800x480 Dots with 1.2 million pixels
Optical grade polycarbonate screen cover with Antireflective/Antiglare coating
100% digital processing
Analog signals converted to 10 bit digital
High resolution scaling of all images
Wide viewing radius - 130° horizontal and 120° vertical provides superior visibility when the viewer is not directly in front of the screen
380 candelas per square meter (cd/m²) luminance produces enhanced image quality in varying light and viewing conditions
400:1 ratio of contrast between black and white luminance values with response rates less than 30 ms results in excellent quality for moving images
4:3 and 16:9 screen aspect ratios
Automatic NTSC/PAL format detection
Standard inputs:
Composite Video PAL/NTSC with loop output
4 Pin XLR D.C. power jack
Easy to see three color tally indicators
Built in Color Bars
Blue Screen for color adjustment
Adjustment Settings Memory
Fits into Tektronix WFM7F05/1700F05 rack adapter
Optional rack mount kit
SPECIFICATIONS - MARSHALL V-R70DP LCD MONITOR:
Display (Viewing Area) 7" (6.14” x 3.27”)
Resolution (Pixels) 800 H x RGB x 480 V
Dot Pitch 0.065 mm x 0.175 mm
Inputs per panel (total) 2 Composite, 1 S-Video
Brightness (in cd/m²) 380 cd/m²
System NTSC/PAL auto rec
Dimensions 7.60”W x 5.16”H x 2.16”D
Approx. Weight 1.8 lbs
Power Consumption 10-17 VDC, 600 mA
VDVPWR1
Marshall 12 VDC V-Mount Power Adapter for NP-Fxx Batteries:
Designed for users of DV and HDV cameras
Includes V-Mount adapter for use with Marshall Stand Alone Models
Charge from Monitor Power source, car battery or optional charger.
Monitor may be operated while batteries are charging
3 Stage Power Indicator
Charge Status Indicator
4 Pin XLR Male Power Source/Charger
4 Pin Female Power Take Off. Can be used for devices without V-Mount Adapter. Can also be used for Lights or Wireless Transmitters and Receivers.
Durable enclosure
Use the DV-Power pack (V-DV-PWR1) with Marshall Electronics line of Stand Alone monitors. This product is the perfect solution for users of DV and HDV Camcorders and allows you to standardize on one type of battery for a wide range of applications.
Full spec below.
I'm also selling:
Thanks,
Ed
More details:
V-R70DP
Standard inputs:
Built in Color Bars
VDVPWR1
Durable enclosure
