Joseph Stunzi
Hey All,
Being the resident Zacuto fanboy here... I wanted to make sure that you all knew that Zacuto has released a ton of new products (27 to be exact) since NAB. They'll be selling all Zacuto products 10% off through mid-August. And if you PM me, I can even help you get a free zicroMount which can be used in conjunction with Zamerican arms among other things.
However, one of the products I wanted to specifically highlight is the Zwing-Away. The concept behind the Zwing-away adapter is to make any mattebox function with a swing away arm. It's sturdy as a rock (I've seen the prototype) and should last you a lifetime. You just slip you mattebox onto the zwing-away rods and off you go!
If you want to mix and match rail sizes, the Jeep is for you! You can intermix 15mm lightweight, 15mm studio, and 19mm studio rail systems almost effortlessly.
Of note to the studio users is the fact that Zacuto's Handgrips, known as Z-Grips, are now available for 15mm and 19mm studio configurations.
There are tons of new products ranging from updated Zamerican arms to new zicroMounts, to Zacuto's own follow focus system.
Lots of new products, so go check them out!
