Park Edwards
Anyone know if you can lock exposure?
SECTION 2 -- A breakdown of D-Movie "mode" features instructions on how to Lock Exposure and what's available in D-Movie Mode
Can someone explain to me why you don't have full control over shutter speed and ISO while using a lens that the D90 can't meter through (AI lens, for example) ? If the camera can't meter, why would it be making ISO or shutter adjustments ?
Rather than thinking of D-Movie as an adjunct to the still photographic features of the D90, realize that it is a feature tacked onto Live View. Live View chooses a CMOS shutter speed and ISO to allow for a reasonable preview image for the still photographer's picture, rather than using the ISO, mechanical shutter speed, and aperture that are set chosen for the actual making of the still image. D-Movie is a quick and simple way to record that stream of info from Live View.
This is hands-down the best, clearest explanation I've read of why D-Movie mode is so peculiar. Thank you! Somebody should give you a raise.
SECTION THREE
DISCLAIMER (9:28 PM PACIFIC) -- No matter what method you use, the key ingredient to repeatable results will be a Manual Lens.
After you're done being mad at me, strap on a Nikon Nikkor 50/1.4 (or Similar) and try this:
....1. Without engaging LV mode, set the camera in Manual Mode. If you're already in
....... Live View, exit. NOTE: The Viewfinder will automatically disengage the meters
....... (AE-L (hold)) If you wait too long. The original time is four (4) seconds. You
....... can set the time-limit to a longer length by going to: Menu > Custom Settings (Pencil Icon) > C (Timers/Ae-Lock) > Auto Meter-off Delay > Select amount of time.
....2. Turn on AE-L (hold), you can check to see if it's active by peerin' into the viewfinder for the AE-L icon.
....3. Close your Iris down to an f5.6 ~ 8
....4. Aim the camera at a wall or surface that's brightly lit. It should not be blown out, but bright. ....I would say just about sixty-percent (60%) Exposed or a little more.
....5. Activate LV mode.
....6. Open the Iris to a 2.8 or 1.4 and check the cleanliness. Not to mention the 1/30 ~ 1/60th shutter. Mmmmm. Delightful.
Ha! Found out how to stop it from turning off so fast:
Up to 30 Minutes before it turns off if you want. Set my own to 1 minute. Updating the method.
So this means that you can record up to 30 minutes straight instead of the 5 min limit?
Quick question, as I'm on the verge of buying one.
When you lock the exposure for video mode... do you have to go through the menu each time to adjust it when you want to switch back and take still photos?
