Zak,
Was that the highest quality 720 recording mode? If that's the raw file, wow, that is WAY too much compression for acquisition. QT player says its 10.41 mbs--from MJPEG. Yeesh.
Definitely less wobble on the wide end, it would appear. That's good.
Thanks for the clip
i see the datarate varies on every single clip. Kholi's have come in anywhere from 21mbits/sec down to 14mbits/sec depending on the clip.
Uhm, here's a theory: Is there any possible way that a cold camera could shoot better footage than a warm camera?
In the Manual, as I pointed out before, it says that the image may suffer from noise when the camera is warm.
Can this thing just not sit in LV mode too long or the image will suffer?
Or, is it the shorter the clip the better the compression?
There could be something to that, but I think the issue is simply over-compressed JPEG. That's how the photojpeg codec works when you encode with it--less detail in the scene, more compression for a selected quality level. It's VBR encoding without a minimum bit rate, which is too bad. I also see aliasing issues on those blinds at the end of the clip, that is probably the macroblocking of the big JPEG compression, and possibly so-so scaling in-cam.
1st things 1st...hello all...I live in uk so we cant get one of these yet....ive been reading the thread here since the news about d90s release....well done kholi n zak for your enlightening early shots(never easy on a new cam,let alone an slr).
The wobbly walls on the whip-pans dont worry me...big worry is zaks kitchen cupboards(wooaahh compression like some old mpg1 playstation pirate dvd)...
btw Zak..this is seriously off subject..I love your polished wood floors![]()
I love how the blowouts look, seriously. nice clip, Zak. Stabilizin' this thing helps a lot.
