There's always a way to figure out how long the exposure time is. If you can't get a number from the camera it will be harder but not at all impossible.If there is indeed no way to know what shutter speed you are at while recording, then this is definitely not The end of 35mm adapers and hv20s...
- The sample looked over exposed.
Maybe not impossible, but I'd rather take my HV20 with me than lug around an oscilloscope for example.If you can't get a number from the camera it will be harder but not at all impossible.
If there is no possibility to manually control the shutter time then I think I will make my own "exposure unit". It will be attachable to the front of the lens like a lens cap. My idea is that it will contain a PCB with like 10 LED:s and a microcontroller. The LED:s intensities will be dimable by the microcontroller. There will also be a mode which moves the light from one LED to the next in a high speed similar to how the ray sweeps in the oscilloscope. That way I can dim the light to an appropriate level, then lock the exposure, then check the exposure.Maybe not impossible, but I'd rather take my HV20 with me than lug around an oscilloscope for example.![]()
Since Kholi says that the shutter speed isn't manually controllable and since I can't see any motion blur in Joes video I'm skeptical to whether the indicated shutter speed of 1/60 is really correct.he used a handheld to meter but that has nothing to do with matrix
actually how did you set iso 1250 manually?
When I was playing with the camera last night I pointed it at my computers LCD. I don't know the proper nomenclature but could see the scan lines crawling down the screen. I reset the AE-L button at a couple different brightnesses and pointed it back at the LCD. The scan lines were crawling at the same rate. This would indicate to me that the shutter was in fact not changing just that the gain was somehow different.
