Zak Forsman
Major Contributor
the challenge is to get Vegas to export in a format ProTools will ingest AND keep adam's audio edits, clip names, cross fades, panning, et cetera intact with handles and changeable, not "fixed" as they would be by exporting each track as a 90 minute AIF or uncompressed WAV. (i guess, realistically you'd export by reel so they'd be much shorter, but still.) if adam goes the "export each track" route, he'll need to undo all the audio work he did, roll out each end of each audio clip to give them 1 or 2 second handles, which means he'll need to stagger them alternating between two tracks because the handles will overlap, then remove cross fades, plugins, pan everything center unless its a true stereo source, etc. big, big PITA.
any way to convert a vegas sequence to fcp or avid?
