Look at the "HMC150 questions answered" thread for some example pics of using my 82mm Letus Ultimate with a 72-82 step-up ring on an HMC150 (same lens and chips as an HPX170). Short answer, it'll work right now.Would there be any noticeable difference between using an 82mm adapter with an HVX200a and using it with an HPX170 and a step down ring?
Actually, this is a good point. I put the Ultimate right on the 150 and it looked pretty good, but I was also going for extremely shallow DOF so edge softness wouldn't have shown. It's possible that a new achromat may be necessary for extreme clarity edge to edge.The HPX170 has a new lens so it may need a different achromatic lens just like the Sony X1.
It seems the general gist is that the EX1 fix achromats or GG units improve the results for panasonic cameras as well. Thus, I think an EX1 type of adapter would deliver good results for the similar HPX. I would consult with the HVXa owners as well to see if they have noticed anything significantly different. My guess is no.
Can't say for sure, but I can't really think of why there would be.Is there any advantage to the wider angle of view lens on the HPX170 for 35mm adapters?
Same lens, same chips, should deliver optically identical performance.Is there any advantage between the HMC150 or HPX170 when using with a 35mm adapter?
I don't know how all adapter manufacturers do it, but I know Letus offers different native mounts, you order it for the camera/size that you want. I've used a 72mm Letus Extreme on an 82mm HVX using an 82mm->72mm step-down ring, and it works great. I've used an 82mm Letus Ultimate on a 72mm HMC150 using a 72mm->82mm step-up ring, and that worked well too.Also, is the native thread mount (I'm sure that's not the correct term) for an adapter 82mm or 72mm? Let's say for a Brevis?
Another naive question. Are the focus assist features of the HMC150 and HPX170 rendered moot when using a 35mm adapter?
