Richard J. Johnson
Joystick Member
I was wondering how much sense it made to shoot my twilight fest film in HD when I really don't know anything about the workflow regarding HD and the p2 cards.
It really is quite easy -- shove the P2 card in, record, and then copy the files off the card to your computer and open in FCP (or whatever NLE you're using). Much faster and easier than capturing from tape!
Tim and Mark seem to have no problems with it...:beer:Judging from the stickies, P2 to Mac isnt that cut and dry. Has that changed?
...then copy the files off the card to your computer and open in FCP...
First, let's talk about what you simply must not do.
1) NEVER put a P2 card into a Mac, or into a reader or camera connected to a Mac, unless you have first write-protected the P2 card. Failing to do so will result in the Mac's OS writing files to your card, which apparently can cause file corruption when you copy the files over.
2) DO NOT use Finder to drag and drop the contents of the card over. I don't care that this has worked for you in the past, and I guarantee that people who have glitches do not care that this has worked for you in the past. Apple, Panasonic, and DVXUser all say don't do it. If you use Finder to drag & drop, any glitching that results is your own fault.
