David W. Richardson
Chapelgrove Films
Or hire someone to put in the muzzle flashes for you. Can't cost much. Certainly a lot less than it will cost to settle lawsuits.
Good luck!
Good luck!
You said:And BTW, a blank by itself HAS been known to kill a person.
Me said:A blank, when used properly, cannot kill a person in this way.
Hi David - just to close the loop, the person you were referencing with the "blank gun to the head" was the Jon-Erik Hexum I mentioned earlier.
It should be noted that it wasn't a purpose-built blank gun like a Kimar or Bruni; it was a standard "real" revolver loaded with blank rounds.
Purpose-built blank guns do have the barrels blocked and are designed to vent the blast and gases away from the line of aim.
