4 audio tracks on LCD screen
homecut
How can I see 4 audio tracks modulation on the LCD screen ?
How can I change the gain of track 3 and 4 ?
thx
I guess you will receive negative answers on both: No and No...sorry for that..!
You cant change the gain of track 3&4 as the cam-micro is set to "automatic" when you use external Mics on 1&2....
You can see the 4 Tracks when you have copied the clips to your computer..in the P2 viewer for example..
Note: the audio levels are not set to automatic; there's no automatic level control at all in an HVX200. Channels 3 & 4 are set to a fixed gain level, which is equivalent to putting the potentiometers at top dead center.
Sorry Barry,
"automatic" was probably not the right term....however, there is no way to control the levels on Track 3&4....i was assuming too that the internal mic has a limiter...
To clarify, the dials always control channels 1 & 2, but channels 1 & 2 can be either the internal mikes or the XLR inputs depending on how you have the input select set.
