Segarza
Hi guys!
I've started doing some tests for an upcoming project that requires extensive chroma keying. So far I've shot 720/24PN and 1080/24PA against a green screen using daylight balanced lighting setup.
I tried both AE's Keylight 1.2 and Primatte 4.0. I've gotten much better results, most importantly repeatable results, with Keylight.
My first attempt was a nightmare, I shot a female (walking and talking) with no backlight against a green screen (720/24PN, daylight balanced lighting). Everything BUT the hair keyed out perfectly. Tried layering several keys, really tight garbage matte, blurring the chroma channels, etc etc. And just couldn't make the jittery noise around the hair go away.
The second attempt went much better. I shot 1080/24PA WITH backlight (daylight balanced). I managed to pull a pretty decent key of the same subject. When composited against a solid color "acceptable" levels of noise around the hair would be noticeable. But when composited against video footage, the noise was barely noticeable.
I've still more testing to do. Can anyone out there share their experience?
Please correct me if I'm wrong, but a green screen should allow for a cleaner key?
Are the HVX CCD's natively tungsten balanced or daylight? Would changing my lighting setup to a tungsten balanced setup make any difference?
Thank you!
Thank you!
