Reflections on HVX200 & shooting feature film
I'm 2/3 of the way through shooting a feature length film with a pair of HVX200's (one an "A" and one the original model), a pair of SGPro adapters, and a pair of FS-100's. For what it's worth - a few thoughts:
FS-100: Great so far. Rock solid. One even got dropped once from about 4 feet onto asphalt and after a re-start has performed flawlessly. However, the cooling fans in these units are a MAJOR design flaw. I got these in the winter and never even heard them turn on, but indoor use during the summer makes them wail like a siren.
I tried using 15' firewire cables to place them in another room, but this is a major pain in the arse especially when you have monitor and audio cables all over the place.
In tight quarters, even when the fans are not running, I can hear the drives spinning. FE needs to address these noise issues with their FireStores I'd say.
HVX-200A: Noticeably cleaner image than the original model and possibly a better built-in LCD screen. I won't use anything above +3 gain with the original model but +6 on the "A" still looks good in my opinion. Also, the "A" is definitely more light sensitive. The "A" is definitely improved.
SGPro: Love these far more than M2. No flip, no problem - monitors are easy to flip. And I can review the clips on a laptop and use QT Pro to flip if I need to. However, the baseplate supplied is nowhere as good as the RRM M2 baseplate which I'll be buying soon to replace the SGPro baseplate. It's far too skinny and does not provide enough surface area for a mounting plate to grip to. Even setting the camera down on a flat or nearly flat surface with the SGPro baseplate becomes a problem since it just tips over.
On-Board monitor:
The first chance I get, I'm buying an HD LCD screen for on-board use. I'll never use an SD LCD screen for on-board use again. I can't stress enough the importance of a high res on-board monitor especially when shooting with limited time or crew. Judging focus and to some degree exposure is SO much easier and accurate with a high end on-board unit. For anyone thinking about what to spend money on - think about an HD on-board LCD before anything else.
Monitoring in general:
It's absolutely essential whenever possible to have someone you trust (if you are operating camera) to sit and watch the monitor while shooting footage. Also, whenever possible, I'd recommend using a CRT monitor larger than 9 inches to judge color and sharpness. Having someone you trust watching a real monitor while you operate camera and tweak lighting is worth it, whether it's a gaffer or a DIT, or just someone you trust - this is major.
I'm 2/3 of the way through shooting a feature length film with a pair of HVX200's (one an "A" and one the original model), a pair of SGPro adapters, and a pair of FS-100's. For what it's worth - a few thoughts: .
Thanks Chris ! What a relevant piece of info, and i'm totally with you on the HD/LCD monitor item... I just wish i could afford one ! See, i'm a (really) cheap producer who always needs to find the trickiest tricks to save money on gears, and since i haven't really started using my HVX + FS-100, yet, i'm definitely going to put some brain and energy into solving the noise / reverb issue you just brought up.
PS: I attached (i think) one of the tricks i found to free the top of my rig, while using both HF-mics and FS-100 It is: 1) saving me A TON of money, 2) balances the camera, 3) adds stability to the HDD itself, 4) offers room for an extra drive, 5) makes acoustic isolation possible (by wrapping that whole thing with appropriate material that won't be in your face when operating). And as i said above, most importantly, it 6) frees the top of the rig to add or position a #%^!@# expensive HD-LCD monitor i'm still wondering why, on earth, didn't just come with that camera !
Thanks JM. Nice clean looking rig, unlike a lot of the 50's era jet pack controller-looking camera rigs I see a lot. I have a really simple solution for mounting an onboard monitor that places it up front mounted on the end of a 9" piece of 3/4" square aluminum tubing. I wish I had a picture, but I'll post one in a day or so.
Basically, I use the Cavision handgrips and I bolted the square tubing piece to the top of the mounting block for the handgrips with the monitor connected to the end of that with a ball-mount. I always thought the Noga arm mounting of an onboard LCD monitor from the top shoe was a little wonky for my taste.
I just bit the bullet and ordered a 7" Marshall HD LCD monitor so I anticipate having to extend the left handgrip from the rails to make up for the extra weight on the left side of the camera.
Why would you need three HF receivers on the HVX when there's only two XLR ports? Or is this some kind of wireless mixer-to-camera-and-back setup?
I keep tellin' people this. It's a must-see-to-believe situation. You can stretch the A to +9 and that's where it begins to tear, but under that it's TOTALLY freakin' acceptable which means the camera is effectively a good 2+ Stops faster than the original 200.
And for someone using a light hungry SGPro that's probably a blessing, man.
My experience is identical to Kholi's. I just sold my 200 and bought a 200a. IMO it fixes the only really significant performance shortcoming of the 200 (price considered). Couldn't be happier.
