Gohanto
Writing a good script is really the trick. First of all, you mentioned "I have no idea how to condense it into 6 minutes" which might mean the idea is just too complex. Look at the top 2 films of LoveFest and how simple they were. Simple ideas, done well. Doesn't mean you can't do a complicated plot, but many films end up feeling rushed and it's very challenging to walk that line.
Another note, if you see someone you really like in another film or even a stage play (careful with this as sometimes what works on stage doesn't translate to film), you can usually find out their email and send them the script. Flattery goes a long way in addition to have a good script.
Also, on top of getting good actors you need to be able to communicate with them as word may get around you don't know what you're doing if you're not completely and correctly prepared. Hopefully you've read "Directing Actors" as that should give you the ground work to communicate effectively and professionally with actors.
Best of luck to you.
