FS: SPLASHBAG (EWA MARINE) for HVX 200 $425
anothermember
http://farm3.static.flickr.com/2016/2453088564_7b237d2af3_b.jpg
http://farm3.static.flickr.com/2288/2452268009_456a47bcd7_b.jpg
http://farm3.static.flickr.com/2321/2452270725_e4c90b1747_b.jpg
http://farm3.static.flickr.com/2099/2452273611_c7e502b2b9_b.jpg
http://farm3.static.flickr.com/2049/2452276863_d601df5653_b.jpg
Originally Paid: $580
After one use, you can buy it for : $425
The Ewa Marine (model # VP2) splash bag is designed for the Panasonic HVX 200. It has been used one time, for about 45 minutes. (I bought it for some underwater shooting in Hawaii a couple weeks ago.) The bag worked fine, but I don't shoot underwater stuff normally and don't need it taking up space in my apartment.
It has very little wear; just a couple scratches from the camera, including a nick right around the xlr input area from the xlr release tab. There are NO LEAKS. It worked perfectly in the ocean, I pulled it out and rinsed it with fresh water, cleaned it and sent it back to LA. Then I re-submerged it just to double check that nothing happened to it in transit and then re-cleaned it. I am a full time camera assistant (union) and very meticulous with my gear.
SPECS
-Rated to 33ft/10m underwater
-Optical Grade Lens Port
-15"x3.5"x11.75"
-1.75 lbs
COMES WITH
-Yellow carry case with waterproof interior and exterior zippered pocket
-User Manual
-Silica Packets (to prevent fogging)
-Foam Padding
-82mm filter ring adapter (screws onto HVX lens so that the lens fits snugly in the lens port)
For full specs check out Ewa Marine's Website at http://www.ewa-marine.de/index.php?id=381&ca=&ra=&ext=&model=Panasonic AG-HVX200&L=0
THE CAMERA IS NOT INCLUDED with the bag, it is only for demonstration.
