We’re selling our trusty and beloved Marshall 7 inch monitor. This LCD is in perfect working condition anf for the most part looks good esthetically. It does have a very minute scratch on the protective plexiglass not on the LCD and is not visible while operating nor does it affect the image at all.. It has a Panasonic battery mount and we have added plates to all the sides so you can mount it any way you want. It comes with a Panasonic battery (3-4 hours) and 3 BNC to RCA connectors. We’re selling it because we have two RED cameras and have no need for it anymore (it was mainly used for the HVX-200)
It retails for $1500
Selling for $600 plus free USPS shipping.
Specs are:
· High Resolution 7-inch widescreen 800x480 Dots with 1.2 million pixels
· Optical-grade polycarbonate screen cover with Anti-reflective/Anti-glare coating
· 100% digital processing
· Analog signals converted to 10-bit digital
· High resolution scaling of all images
· Wide viewing radius
· 380 candelas per square meter (cd/m2) luminance produces enhanced image quality in
varying light and viewing conditions
· 400:1 ratio of contrast between black and white luminance values
· 4:3 and 16:9 screen aspect ratios
· Automatic NTSC/PAL format detection
· Standard inputs:
· Composite Video PAL/NTSC with loop output
· Component YPbPr HD/SD with loop-out
· 4-Pin XLR D.C. power jack
· Easy-to-see three color tally indicators
· Built-in Color Bars
· Blue Screen for color adjustment
· Adjustment Settings Memory
· Includes universal voltage Class-2 power supply
Specs are:
· Standard inputs:
