Thank you Barry! That worked.
One more n00b HPX500 question, on our old cameras when we chose Preset and went outside it would switch to 5.6k and indoors 3.2k...seems that we have to manually change it everytime for preset or is it possible to set it to automatic??
Thanks!
It is as seamless as the button to go between 5600 and 3200.
I have asked that the next camera have different language, but the HPX500 cannot be changed at this deep level of software change.
Sorry,
Jan
Dave,
Unless I am missing your point, the 500 has 2 factory presets; a 5.6 setting and a 3.2, as well as 2 customizable presets. All switchable on the fly without having to use a menu or remove the camera from the shoulder.
All I do when moving from outside to in, is reach up and flip from one to the other. One does not have to go through the menu, and I find that it actually is quite seamless.
-Brad
Brad, you have A and B then the preset....the preset should automatically change with the rotating ND filter dial. If you have 3.2 set in the menu for thw WB preset and choose ND 3 for outdoors, it stays 3.2 and everything will be blue! Other cameras switch to 5.6 with the preset.
For the customizable WB A and B thats another story....you need to do a WB everytime and in alot of places you have no control over the situation and you will be forced to use a preset...the whole point of a preset is that...its a preset and you dont need to do anything to make it work. Maybe you guys are used to the DVX and HVX, but we use ENG style cams and this missing feature is ridiculous.
