jeremytuttle
Not sure if someone suggested this specifically, but if could shoot with something with a little more res, even DVX, and zoom out a bit and have two small sections of set almost butted next together and have an actor at each "set". In post (after effects probably or a garbage matte in any NLE) you could cut them up (cut in half) and put them where ever. So then you would only need 5 cameras if you shot them at the same time.
Also, I think and mic with a large pattern would work for two or three actors. So then you would only need 4-5 mics... but I'm no audio guy so that is just a guess.
EDIT: Actually with the green screen idea, why not have all three in the shot. Then all you need is a small piece of desk big enough for a keyboard and mouse for each actor. THen cut them all up and place them where ever and key in your backgrounds (I know a little easier said then done but it's an idea)
