I know I might be wrong but I thought that 50i is just 25 frames doubled...so I wonder why its better quality and more video like. I bought the DVX102b which doesnt seem to have 30p.
50i more video like yes, better quality no. progressive is a full frame, interlace is a half frame therefore half the quality as a full frame.. Where did you read that? You got a PAL camera. NTSC has 60i, 30p and PAL 50i,25p. what County are you in?
I'm in England but I went to singapore on the way home from Australia and bought the DVX102...So I was right in saying that the first frame is repeated and so on for 50i so really 50i is only good for slowmo? thanks
No, the first frame isn't repeated. 50i isn't even frames; it's half-frames, or fields. Each field represents a new reading of the CCDs, a separate moment in time. It happens 50 times per second, so each 50i field is new picture. Anything moving will be in a slightly different place in every field.
Which is why you can'd just splice them together to make a frame, and why you see the comb interlace artifact on anything moving when you do.
