EX1 and RED playing nice together...
Tungsten is worse for the CMOS cameras because the prevailing CMOS cameras (EX1 and RED) are both overly sensitive to infrared. I don't know if that's tied to CMOS or if it's just coincidental that both of these cams don't have strong-enough IR filtration, but tungsten lighting will wash your scene with more infrared than daylight lighting will. If your camera's subject to IR pollution, using tungsten lighting will exaggerate it and daylight lighting should minimize it.
I built a small 700sf greenscreen studio and lit it with $20 Home Depot shoplights with T8 electronic ballasts running high-CRI daylight fluorescent tubes, I think it's like $8/tube. That's for along the top. Then I fill in the sides with two CL655 fixtures, all daylight. Could just have easily been a jerry-rigged solution of banking more of the shoplights together, for that matter, but I used the shoplights for the permanent install across the roof; for the movable lights I wanted to use something more designed for the purpose. The screen itself is 24' wide by 9' tall and is lit with those six fixtures quite well. Four evenly-spaced 4' 2-bank daylight lights up top (would have been even better with 4' 4-banks) and then low and to the side I have some six-bank fluos. All light is at a 45-degree angle to the screen to make it all wash appropriately and smoothly across the screen. Just get your actors away from the screen to keep your actor lighting from polluting the screen's lighting (which would result in shadows on the screen, etc). I typically light the foreground with my CaseLites or Scandles, all daylight; also got a CL-SFT1 for a big softbox for $125, not bad but a little buzzy and not the best for getting close to someone you're going to be recording dialog on. For hard light the little Cool Lights 150W HMI works a treat as long as you can keep it away from the microphone, it also buzzes, moreso than the CL-SFT1. Basically the entire studio is daylight, and it wasn't expensive at all to outfit it that way. Plus it runs so much cooler (less A/C needed etc) and on less power (I think the entire place, fully lit, foreground and background, rarely pulls more than about 1,400 watts).
You'll get noticeably cleaner footage (and thus better keying) on a Red if you use daylight light. Don't know how the individual channels' noise shows on an EX1. It could just be the way RedCode deals with the blue channel; they've talked about significant image improvements in the next build.
Half-blue will help, 1/4 will help, but obviously they'll help only to the level that you add correction. Half-blue means it will have to gain up only half as much, thus reducing the additional blue channel noise by half. 1/4 Blue will mean it still has to gain up 3/4 as much, meaning 3/4 as much additional noise.
As for whether this will apply to your other cameras, it all depends on where they balanced their sensor. If they balanced for tungsten (and have adequate IR filtration) then going to daylight lighting will make for noisier images. If they balanced for daylight, then going to daylight lighting will make for cleaner images.
Should be easy enough to test though -- shoot your greenscreen as normal, then slap an 80A filter on the front of your lens and balance for daylight and open up the iris two stops, and shoot again (even under the same lighting). This won't take care of any IR issues, but at least that'd remain constant. Then take the footage into AE or somewhere where you can evaluate the individual color channels and see whether the difference is worth it to you. If you've got enough brightness as-is so that you can open up a couple of stops already, the 80A filter might be your entire solution (but I'd still look at an IR filter).
E, I'm assuming that you're going to make a go for the Sensor upgrade when it's released? Is that supposed to be tungsten balanced?
One thing I can't wrap my head around is using Daylight balanced lights or HMI and gels: how does this affect the RED footage as opposed to just using Tungsten to begin with?
I think Barry has answered the second question pretty well...so I won't repeat what he has already done a good job of explaining. And while I will go for the sensor upgrade (and probably upgrade one of my 2 RED ONES to an Epic), I doubt they will change the sensor to tungsten balanced. It is exciting that they have tricks up their sleeve, like a sensor overhaul. Quite a surprise for a company that has been shipping in quantity since only December.
They have surprised many times, however....
I will say that the blue channel using the final release of Build 15 (there are several beta predecessors) is already considerably less noisy than it was in Build 13 (Build 14 was more or less skipped...). So RED has already made some improvements based on its user feedback. And I feel confident that more will come in Build 16.
It will probably take longer to combat the perception that the blue channel is noisy, however, since this perception is now prevalent on various forums. It is always challenging to change those perceptions, when they are so often repeated.
And I would take issue that the IR pollution issue is a problem -- it's more like, something to be aware of.
It's primarily visible if you are stacking filters, so some companies like Schneider are producing 6-stop ND filters (1.8), so that no matter how bright the light, you won't need to stack.
And Pancro (http://www.pancro.com/) has recently produced a solution which combines IR filtration with a strong ND.
I live in Colorado, which is known for its thin atmosphere and bright sunlight, and I have not yet used an ND higher than .9 -- perhaps I should take my camera into the high country some time soon and do some testing on snow glare because it doesn't get much brighter than that...
Thanks Barry,
Very helpful as usual (really man I still love ya!) For me the home made blue screen studio is not an option, so its how best to handle on a stage with a gaffer's truck. Space lights would be the biggest issue, but maybe just a blue lens filter and a stop or so more light might be the best bang for the buck. You'll lose as much light with blue on the lights as you will over the lens but its a lot faster on the lens and tungstun is usually a faster cheaper way to go on a stage.
The IR thing still has me confused . I've been following the discussion on DVInfo.net and there seems to be a potential problem with at least the 486 Schneider filter introducing green vignetting on wide shots under tungstun. Haven't gotten a clear answer about that.
At NAB Tiffen showed me some IR ND filters they were making but they were going to be very expensive.
Lenny Levy
This is not the news I wanted to here. I was banking on a RED camera this Dec.
Im now thinking Ill keep working with my EX1 and build my Canon full frame camera. Im sure Ill save lots of money.
The Red One simply blows the Sony EX-1 out of the water. I watched some cool skateboard video shot with Red One at 1080p and 120 frames per second for some awesome slow motion. Can Sony do this? No way. Sony maxes out at only 30 frames per second for 1080p. If the Sony could do 720p at 120 frames per second I would be happy but even at 720 Sony maxes out at only 60 frames per second.
