Kinda James Bondish. Close it up and go.
I'll catch up on the thread and get some juices flowing... but back when I wanted to do a light like this I figured the most basic way to make the light modular would be to offer a frame. I was looking at extruded aluminum channel to accomplish this (cheap, easy)... so that basically you could slide the lights into a track in order to build a single larger light. If the light structure itself is very solid then you wouldn't need a full track (for say, 4 lights or less) but perhaps just a channel connector at each union (from the sides) and then perhaps a "cross" at the center. The outer channel track could simply be U channel... shaped like this l_l and that would slip over a couple inches of each fixture. 2 of those to put two lights together and 4 for 4. The cross center support could slip in at the center, and attach to each of the 4 lights strictly from the back... unifying the assembly of 4.
Hey about the attache' style light... I worked on that also. I like the caselight concept for the travel protection it provides. I looked into laptop attache' cases to accomplish this... as well as regular aluminum briefcases. This is how I ended up with the look of the DIY LED light that I built for myself... thinking along those lines. I guess it's about time to post a picture... Since members are starting to think along the same lines. As you'll see my fixture doesn't open up into two sides... but attache' style LED light is a good way to describe what I was going for. Pictures coming... gotta' go snap a couple.
Someone tried this yet?
http://www.led-z.com
If 1 of the LED-Z are good think what eleven would be like. I finally finished and used my LED lights on a couple of shoots and really the benefits of LEDs.
