Broad Reach Images
I got the chance to shoot the EX on a few jobs recently, and while I have been very impressed with the quality of images the camera captures, I ran into some issues and inconveniences which have left me with a bad first impression of the camera. I would love for any feedback on whether I am in the minority, or if others feel the same.
My first issue with the camera comes with the menu system. I have seen other threads on this topic so I will not dwell on it too long, but it seems to me all the functions one would use most often are buried. i.e. formatting cards, switching record format / frame rates, and steady shot.
This first issue would not be such a big deal for me if the scroll wheel was more user friendly. Maybe it is something I would get used to, but when under pressure to change menu items quickly (mostly fps) I found the selector jumping all over the place as I inadvertently hit the wheel in the wrong direction. (The toggle which I finally discovered would have been a way better primary option).
Because this shoot involved a lot of interspersed 60 fps while shooting the rest of the content at 1080 30p, the process of switching the record format, then having to change the S & Q motion setting became cumbersome. Not to mention if the camera was shut off the S & Q motion setting turned off and needed to be reset. I realize these are just operator inconveniences and probably in most situations do not apply, but comparing it to the HVX I feel Sony has missed some obvious cues. Why are the assignable buttons, all of which are almost too accessible, ( I hit them by accident from time to time) filled with mostly, in my opinion, worthless settings? It seems they could be put to better use. Also, upon reviewing 60 fps shots on a bigger screen they looked soft. Our fix was to bump the shutter speed up to 120. Yet another menu item to click during a record change.
Probably my biggest issue with the camera is the EVF. I tried for about 40 minutes to get it in at least the same realm of the LCD, but it never came close. The image seemed always to be slightly washed and blown out. Now, the high resolution LCD is an amazing feature. It is a pleasure to review shots on, but in bright outdoor light it is not much better than any other LCD. Without a hood for the screen, and a barely functioning EVF, which I always would use in outdoor light, one is restricted to working off the zebras and hoping that the washed out image in the EVF is not what is being recorded. Not something I feel we should have to deal with in this day of age.
Other inconveniences I encountered were no preset for 5600k, not being able to fit a standard circular polarizer under the matt box, dealing with its poor weight distribution while hand held, a power switch one needs to really concentrate on in order to change correctly, having to cycle the camera through ‘off’ to review media disrupting some settings, and lettering on the camera that is already fading. (Has anyone else had this issue?? I was told this camera was only about a month old with light use and I could barely make out the ‘1’ and ‘2’ on the ND filter!)
There are things I like about the camera, the lens is great, and while I know that at the end of the day all that matters is the final image, I firmly believe usability is a piece of the puzzle.
Thanks for your thoughts and consideration.
