so the marking wheel stays put and the knob with the arrow rotates around?
One other feature that I am thinking I might add at this stage is a pause button. If you set your focal distance and you do not want to loose it (other than drawing a line on the marking disk) you can press the pause button. This will lock the servo at the current position and turning the knob wont do anything. When you press the button again it will revert back to normal mode and it will jump to wherever the knob is at that moment.
Are these updated and changes a good thing? Im still looking at about a month for a fully working unit...
Thanks for any input....
... The only additional cost will be the buttons, the actual circuit costs no more than the old analogue one.
