What arm do you use with your Panasonic monitor?
robmneilson
Ive got a noga arm, but I think it may be a little flimsy when I get the monitor, since it only supports 6 or 7 pounds.
What arm do you use? What size thread does the Panny monitor have as well?
Your Noga should be plenty strong enough. Your monitor is not going to weigh 6 pounds unless you use a V-lock or larger battery.
I have an early version of the Zacuto set up which uses Noga arms. I use the Marshall 7" monitor and my Noga does a great job.
Jim
My Panny BTLH-80w with an IDX battery weights just a bit under 6 lbs.
I've been looking for a good way to attach it as well. Zacuto is great, but very expensive.
I know this has been covered pretty extensively in other posts, but I havent seen anything recently.
I'll be watching to see if anything new pops up.
Mike
