pingpongpete1
I have been filming a lot of music on indoor stages with my 18-month-old DVX100B.
I originally had a major problem with audio when I was using the camera in a roving role, with the built-in mics: they basically can't cope with typical live gig sound pressure level if you're anywhere near the speakers. (Presumably a consequence of upping the audio sensitivity on the 100B?) I've solved this by 1.) having a little T-bar made which fits into the accessory slot, and holds two small Calrec condenser mics in a crossed pair; and 2.) buying a pair of 20dB XLR attenuator leads for use when necessary. The camera is a bit heavy and unbalanced, but at least the sound is decent indoors in any circumstances.
Now a remaining problem is colour balance. It's obviously impossible to set up white balance like you normally would; too far from the stage, widely varying lighting conditions which are deliberately abnormal, etc.. So I tend to use the factory preset FLOU scene, and 3.2K preset white balance, or sometimes ATW. (I have tried every other preset and combination with no better results.)
However I set the camera, magenta lights come out as orange-y red. I don't remember that this was always the case - I have some images from a show last year which are full of magenta - so I'm wondering if a fault has developed. All other colours seem to be faithfully reproduced.
So, has anyone else had this issue? I'm reluctant to set up a custom scene setting if it's only counter-balancing a likely fault.
