If you get one, Dan, can I play with it?![]()
Richard:
Any indication on when you will have the 575 HMI back in stock?
Also, how long do you have to wait to re-strike it when you shut it down?
Dan
Ew Zander!
On a serious note: Richard, is the 575w HMI focusable like the other Fresnels or does it have lenses to move it from spot to flood, etc?
Hi Dan,
We have maybe 3 left in stock now but the reason I have people contact me is I feel that this is a beta unit right now and I qualify that with customers so its not online ordering to just anyone. Expectations have to be set that this is a bleeding edge product which we don't know all that much about how reliable it will be yet. So far so good with the units we have out there. Little problems mostly with the yoke not holding the angle properly but I'm not overly concerned about that and it should be fixable in the final production models. Another issue is a faint electronic whine from the bulb due to the fact that we drive it at such a high frequency to avoid flicker at any FPS or shutter speed. I don't believe this noise is a problem to most people who have a subject and their microphone in a normal position and the light also in a normal position (i.e. not right next to the microphone). We may not be able to work this out of the production models as its a tough problem to solve. The fan noise on the ballast itself is acceptable and very "whisper" like.
From a light output standpoint they work fine and are comparable to an Arri 575w HMI fresnel in output, or maybe just a bit less. What can you expect for a product that's about 1/7th of the price of a comparable unit?
In any case, with this test, I want to develop a history on this ballast which is new before I put it out in full service. Once the test is over in about 6 months or so, we'll ramp up full manufacturing on it. So far, we only had to swap out one unit that failed.
Richard:
The loose yoke would be a big deal for me as I shoot a lot with Chimeras and I need the lights to stay where I lock them down, that is one thing I like better on my Moles over my Arris, the moles have a metal yolk and lockdown and they stay put, the Arris with their nylon lockdown have a tendency to slip. My advice would be to spend a bit more and use a metal yoke with a metal lockdown ala Moles. This is a big deal for many DPs and gaffers, and it always has been for me. I have figured out workarounds but it's a PITA.
Do you anticipate the price on them staying the same or increasing when you finalize and ramp up?
BTW, I did a shoot last weekend with a rented LTM HMI 1200 watt PAR and most of the HMI heads make a high pitched whine anyway so thats not a big deal. It's in a frequency range far above the voice so it can be removed without killing your dialogue.
For certain shoots with live music, it could be bad but for dialogue, I have never had a problem with it.
Best,
Dan
