12" Powerbook 1.5 G/512 fs/80GB HD
skycron
I have a Powerbook G4 that I'm considering retiring and selling toward a newer machine, and I'm putting it out here as a feeler if anyone's interested and what it's worth. I'd hope to get a few hundred dollars for it but any reasonable offer is welcome. I'd probably get a used 17" Powerbook or Macbook which to my shock is rather cheap (the Powerbooks at least) on eBay.
The thing works flawlessly, only hiccup is the Superdrive gives a hex error from time to time, refusing to burn. It's a pain to fix it but I've done it a few times. I think just the firmware is wonky. Other than that, perfect. Here are the specs:
Machine Name: PowerBook G4 12"
Machine Model: PowerBook6,8
CPU Type: PowerPC G4 (1.2)
Number Of CPUs: 1
CPU Speed: 1.5 GHz
L2 Cache (per CPU): 512 KB
Memory: 512 MB
Bus Speed: 167 MHz
Boot ROM Version: 4.9.0f0
MATSHITADVD-R UJ-835E:
Model: MATSHITADVD-R UJ-835E
Revision: GAND
Serial Number:
Detachable Drive: No
Protocol: ATAPI
Unit Number: 0
Socket Type: Internal
Built In Sound Card:
Devices:
Texas Instruments TAS3004:
Inputs and Outputs:
Internal Microphone:
Controls: Left, Right
Playthrough: No
PluginID: TAS
Line Level Input:
Playthrough: No
PluginID: TAS
Headphones:
Controls: Mute, Left, Right
PluginID: TAS
Internal Speakers:
PluginID: TAS
Formats:
PCM 16:
Bit Depth: 16
Bit Width: 16
Channels: 2
Mixable: Yes
Sample Rates: 32 KHz, 44.1 KHz, 48 KHz
PCM 24:
Bit Depth: 24
Bit Width: 32
Channels: 2
Mixable: Yes
Apple Bluetooth Software Version: 1.9.5f4
GeForce FX Go5200:
Chipset Model: GeForce FX Go5200
Type: Display
Bus: AGP
VRAM (Total): 64 MB
Vendor: nVIDIA (0x10de)
Device ID: 0x0329
Revision ID: 0x00b1
ROM Revision: 2122
Displays:
Color LCD:
Display Type: LCD
Resolution: 1024 x 768
Depth: 32-bit Color
Built-In: Yes
Core Image: Supported
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Display:
Status: No display connected
AirPort:
Type: AirPort
Hardware: AirPort
Modem Model: Jump
Interface Type: I2S
Modulation: V.92
Hardware Version: Version 1.0
Driver: MotorolaSM56K.kext (v1.3.9)
Country: 20 (Canada)
What's the weight of the powerbook, how much are expecting for it and where are you located? I'm very interested.
Studio's in Oakville, but mostly I'm in Toronto since that's where the soundstages are. I'm happy to meet at Union Station or something, done that a few times with people on the board.
The Powerbook is very light. I'd say about 2 lbs. Let me know what you had in mind for price and we can discuss it.
I'm a bit behind in what these things are worth, that's why I'm not really sure what to ask for it.
