Broken Download Links Report
I tried it twice and it worked for me, so it's likely just one or two of the mirrors. Larry'll have it fixed in no time, b/c he's cool like that.
Later,
Jason
I just went to each of the 13 mirrors and in every one of them they have the complete file. So the only possibility is a problem with one of the mirrors, but if that were the case then that mirror would cause problems serving any of the films.
I will continue to look into it and see if I can find any other potential issues causing it, but at the moment there is nothing specific I can do to fix it.
Have a lot of people been having trouble downloading the film?
Just two so far.
I had the same issue with Minogue Space, as did someone else... not sure if that helps.
The fact that both of them stopped early and on different ISP's means something must be up? Not sure what though.
Ok, I just got a partial download ... I think I identified the offending mirror and am correcting it now ... please let me know if you have any additional trouble.
Well... it just worked. But that took a lot of work and Zim was having issues as well. He tried a few times and couldn't get past 12 MB's
Just downloaded it twice now. You sure you didn't flick a switch or something?
:D
I've tried all the zip files multiple times, and I keep getting "Entry ID: 91001 does not reference a valid file." (The entry id seems to be unique for each zip file)
Rarely there will be a "404 file not found error", too.
That's the same message I have been getting. I ended up downloading individuals. Only have the last two compete movies, and the non-competes left to download. Will get those this morning.
I am running current FireFox version on XP. I also tried with ie (not sure the version)
I am hearing there may be an issue downloading "The Simp Takes a Holiday" "That it downloads but it says its not a mov file" per Rob Comeau. can someone please look into it, thanks!
I haven't been able to download anything for a few days now. Download stops at a fraction of a percent, then I get a time-out. This happens with all files I try.
