Tim Naylor
Since we know the LEX has a much larger internal FOV than academy or other conventional standards (see my previous post in this thread for the relevant quote about this from Letus's site), I wonder if someone could try something out while I await the arrival of my own LEX (or point me to another place if someone's already done it).
According to Barry's book, a bare HVX shoots the 35mm still camera equivalent focal length of 50.8mm at a zoom setting of Z25 (or 6.6mm on the HVX's mm scale readout). He's got a wide range of lens lengths and equivalencies mapped out in the book, but since most users have at least a 50mm lens, and it's more or less a "neutral" focal length, it seemed like a good test subject.
The procedure would go like this:
1) Set up a focus chart or other similarly large, finely detailed image, and with the HVX's zoom set to 25 (or 6.6mm), position the camera so the screen is filled with the chart, focus for the center, and shoot.
2) Then, without moving the camera (except to accomodate whatever the difference is between the locations of the imaging planes with and without the adapter), add the LEX (or any adapter, for that matter) and a 50mm SLR lens. After setting it up normally, zoom the HVX to match the FOV as in case #1, and shoot again.
The question is, what HVX zoom setting is the result in case #2?
If it's significantly more zoomed in than what's necessary to eliminate vignetting, then we may have some useful information on minimizing edge focus problems. Presumably, more zoomed in should mean less edge-related issues of all kinds, right?
Furthermore, since we've established a bare HVX vs adapter-equipped focal length equivalency, then we know we're not over-zooming to get that advantage. We've eliminated the adapter's effect on FOV from the equation.
Of course, users could still zoom the HVX in less if they wanted to and didn't mind whatever the effect on the image quality was, but at least we'd know what setting could be regarded as focal length-neutral.
Thanks in advance to anyone willing to give this a shot.
Performed your test except with an 85mm Nikon. It's equivalent field of view in 1/3" chip is 11.7mm. BUt before I reveal the results, let me amend your test - you have to move the camera. If you start with the camera with no adaptor, your focal plane is approximately half way down the barrel part of the body (where the prism is). With any Adaptor, your focal plane is now where the ground glass is. In the case of the LE that's about 10 inches from the HVX's focal plane. So you got to move your camera back about ten inches.
I had to zoom into 69 (17.9mm) to duplicate the 11.7 mm results. At this wide, I am barely past the GG borders and it suffers from vignetting (especially the left side) similar to Kwan's post. To get past the vignetting on a wide lens (24mm) I have to zoom in to 81 (26.9mm). To get past vignetting on my 85m, I have to zoom into 74.
I can draw a few conclusions: either you have to zoom in much tighter than cine 35 FOV to get past vignetting or the HVX's zoom readout is highly inaccurate or both. The only way to really verify this, I guess, would be to compare the FOV on a 35mm film camera or find out FOV in degrees (from some chart out there) and duplicate that.
Eitherway, it would be nice to have a definitive answer for what zoom settings really replicate a cine 35 FOV.
